Engine Mechanical problem
2000 Chrysler Cirrus 4 cyl Two Wheel Drive Automatic
Code is P0135
How do you fix the problem.
And Where is it located.
Sunday, October 26th, 2008 AT 12:26 PM
MECHANIC
Hi:
It sound like the oxygen sensor needs replaced. If you have already done this and the same code is coming up, there must be a burnt or broken between the O2 sensor and the PCM.
