1996 Chrysler Cirrus LX 2.5 V6 STALLS
PLAY_PLAYAZ
  • 1996 CHRYSLER CIRRUS
Ok my 1996 Chrysler cirrus lx 2.5 v6 has issues. First of all I replaced the alternator and the TPS. The alternator change, fixed my high volate at TPS and MAP sensors, but I still have major problems. On an autozone computer test which was free it said fault code p1296 now I can't find this for the life of me. So I basically said forget it. Then I remember I can put my key in the ignition and go on off on off on within a 5 seconds period and it will spit some codes out at me. The codes I got were 12, 14, and 31. What in the world are these and how do I fix my problem? I would really appreciate it if someone could help me I work part-time and go to college full-time.
Daily driving issues are as follows:
I drive the car it runs fine for a while then it shows slight hesitation usually after warming up to temperature.
I continue to drive it sometime it acts as if all power fails then it re-picks up idle after about 5-30 seconds or just dies all together leaving me coasting to the side of the road.
I try and restart the car sometimes it restarts, sometimes it starts and dies about 5 times before it goes again.
It's a royal pain in the you know what. Please anybody =help.
Please email me at play_playaz@yahoo. Com my name is Michael.
Wednesday, May 30th, 2007 AT 3:31 AM
ROBWALL
Hi Micheal, I have the exact same problem. Im in the process of working on it myself. I can however tell what your codes mean. (12, 14 & 31).
Code 12 = Problem with battery connection. Direct battery input to PCM disconnected within the last 50 ignition key-on cycles.
Code 14 = MAP sensor voltage out of normal range.
Code 31 = EVAP system fault.
Hope these help!
Sunday, June 3rd, 2007 AT 3:09 PM
PLAY_PLAYAZ
  • 8 POSTS
Yes I got the same things I know what the codes mean now.
12 Battery or computer recently disconnected
14* MAP sensor voltage below.16V or over 4.96
not sure why it's putting out 14.
31 Bad evaporator purge solenoid circuit or driver
what in the world is what 31 says and how in the world do I fix it?
Sunday, June 3rd, 2007 AT 9:25 PM
Related Engine Stall While Driving Content
