1996 Chrysler Cirrus low oil
13,000 MILES • 6 CYL • FWD • AUTOMATIC
TRAIN52
if my car ran low on oil and cut off bc of it. what would be my next step to get the car back running after puting oil in it. i tried turning it over but there was no spark.
Feb 25, 2009 at 12:54 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Feb 25, 2009 at 6:32 PM
TRAIN52
is it indeed a safety feature for the car to cut off if there in no iol in it? is there a reset switch or something in case this happens?
Feb 25, 2009 at 8:08 PM
  • 75,988 POSTS
There's no reset switch-if your not getting spark the engine will not start it doesn't matter if the oil pan is full or empty of oil.
Check for fuel and spark then get back
Feb 25, 2009 at 9:39 PM
