1996 Chrysler Cirrus low oil
TRAIN52
  • 1996 CHRYSLER CIRRUS
  • 6 CYL
  • FWD
  • 13,000 MILES
If my car ran low on oil and cut off bc of it. What would be my next step to get the car back running after puting oil in it. I tried turning it over but there was no spark.
Wednesday, February 25th, 2009 AT 8:54 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Thursday, February 26th, 2009 AT 2:32 AM
TRAIN52
Is it indeed a safety feature for the car to cut off if there in no iol in it? Is there a reset switch or something in case this happens?
Thursday, February 26th, 2009 AT 4:08 AM
There's no reset switch-if your not getting spark the engine will not start it doesn't matter if the oil pan is full or empty of oil.
Check for fuel and spark then get back
Thursday, February 26th, 2009 AT 5:39 AM
