The gas-gage light is on, the hand is showing empty but the car is full with gasoline. why would is this happening?
Aug 5, 2008 at 12:24 PM
BLACKOP555
✓Experienced Mechanic
first thing would be to check functionality of the fuel guage! best way is to put the signal wire from the fuel pump wiring harness on +12v does the tank guage show full if so the harness is good and i would suspect a bad sending unit in the tank. if not i would suspect wiring harness damage, short to groundsomewhere in the line. OR a damaged guage.
Aug 5, 2008 at 2:29 PM
ZACKMAN
For this particular model vehicle: bad fuel sending unit. Dealership may be able to supply you with just the sending unit, but for the age and mileage, I would recommend replacing the fuel pump assembly Carter P74693M $200, and external fuel filter Fram G7760 $15
Sep 4, 2008 at 12:20 PM
BLACKOP555
still cant rule out the possibility of damaged wiring harness!
friend had a cirrus, had a bad guage i told him to replace the unit.
finds out it wasnt that. NEVER again. since your already down there might as well check the guage.
