I have a 1996 Chrysler Cirrus which cuts out while driving or also while idling. Does it every couple of days. Most times it will restart but other times it must sit for a couple of hours before it will restart (only when I don't have any tools) . Has spark, good fuel pressure when running, and no engine codes. The engine runs fine, good power and smooth idle. Has had spark when it wouldn't start. It can idle for 15 minutes and then just shuts off like you turned off the key. Same way when you are driving it. Sometimes it will it will idle for an hour fine and not cut out. Everytime it has stopped and I put a fuel pressure gage on it it starts. Any ideas. What commonly fails.
Nov 11, 2009 at 9:26 AM
