1996 Chrysler Cirrus camshaft position sencor and circuit m
1996 CHRYSLER CIRRUS
98,000 MILES • 4 CYL • FWD • AUTOMATIC
CHRYSLERCRY
I'm sorry about not being able to make a donation, I am currently a high school student and that being have very little money, anyways my car shut down on me one day and wouldnt fire back up it tried and the starter worked fine but just couldn't get a spark, I know its the camshaft position sensor and circuit malfunction in bank A. I know a little about cars and replaced the camshaft position sensor but still no spark, I'm wondering if you might think its a problem that i can fix, i have tools, or if it would be best if i took it in. I'd also like to know if you can give me an estimate of how much this problem would be to fix. Thank You so much for your time and i'm hopeful that this site may be the end of my stress with my car.
Jun 22, 2009 at 11:55 PM
JDL
  • 16,098 POSTS
Hello, what were the actual codes? With the engine cranking, do you have primary voltage voltage at the coil pack, dark green wire with orange tracer? Is there B+ to the injectors?
Did you check the wiring circuits to the cam sensor?
Jun 23, 2009 at 2:10 AM
