1996 Chrysler Cirrus Belt Pulley
1996 CHRYSLER CIRRUS
JCOELHO85
1996 Chrysler Cirrus 6 cyl Front Wheel Drive Automatic
On my car, i had to replace the alternator, and now after i got everything put back on, i can not get the pulley to tighten the belt. the pulley will tighten on the bracket, but i can not get the pulley to get the belt tight enough. what should i do next?
Feb 18, 2010 at 12:41 PM
CARADIODOC
  • 34,381 POSTS
If you're using the old belt, check the routing diagram on the timing belt cover or radiator support. It's possible to route the belt incorrectly around all the pullies.
caradiodoc
Feb 24, 2010 at 1:34 AM
