1996 Chrysler Cirrus
126,000 MILES • 6 CYL • FWD • AUTOMATIC
COLDDIC
does a 1996 chrysler cirrus have a timing belt and if so when does it need to be changed?
Feb 25, 2008 at 10:53 AM
BMRFIXIT
  • 19,053 POSTS
REMOVE AND OR DISCONNET :
raise and support vehicle
right inner access cover
drive belt
right engine support from frame rail
lower car
support engine with a floor jack remove 3 bolts attaching engine support
right engine mount
crank pulley
lower timing belt cover
upper left timing belt cover
upper right timing cover
let me know if you are going for it
!!!!!!!!!!!!!!lot of work !!!!!!!!
it require skills too
Feb 25, 2008 at 12:40 PM
