My transmission will shift sometimes. It usually works until it gets hot, then it will not shift out of first gear.
Oct 14, 2008 at 4:00 AM
ZACKMAN
✓Experienced Mechanic
You should have your check engine light on. Find out what the codes you get. Most likely you will have to replace the speed sensors, if not the trans control module.
