Make sure the ASD relay inside the power distribution center is still good.
Check fuel pressure at the fuel rail. You should have 50 psi.
Check spark at the plug. Spark should be blue, not yellow.
Advise us with what you find out.
SPONSORED LINKS
Tuesday, February 3rd, 2009 AT 10:19 PM
