1995 Chrysler Cirrus No spark
178,000 MILES • 6 CYL • FWD • AUTOMATIC
CASEY TYSON
I have a 1995 chrysler cirrus with a 2.5. I took to a mechanic and the told me my crank sensor was bad so i replaced so that further tests could be done. Then they tested spark and said no spark was found all the way to distribitor cap but they never took cap off so i picked up car and took cap off and lightly sanded points. I put back together and still no spark. I have seen alot of stuff is commonly bad on this motor but i want to know what is my next step. I know no history on this car i bought it the way it was and it has been sitting since 2005.
Aug 14, 2009 at 6:58 AM
CARADIODOC
  • 34,413 POSTS
If there's a sensor problem, there will be a diagnostic fault code in the computer. Have your mechanic read the codes to get started on the right track.
Aug 19, 2009 at 6:52 PM
