1995 Chrysler Cirrus need an answer
198,000 MILES • 6 CYL • FWD • AUTOMATIC
MABLE84
how will i know if my alternator is goin down?
my car will start , and while it's running it will die out and i don't know what the problem is...so i hope you can tell me
Feb 28, 2008 at 6:16 AM
JDL
  • 16,098 POSTS
You might check troublecodes, a code might point you in the right direction.
As far as your charging system, you can use a voltmeter, place the leads across the battery posts, with the engine running, take a reading.
If you have a charge lite or gage on the dash, that should give you a warning.
Mar 21, 2008 at 8:01 AM
