1995 Chrysler Cirrus Fuel Pump
19,900 MILES • 6 CYL • 4WD • AUTOMATIC
KSMACKEY
I tried starting my vehicle it cranked a little bit but wouldn't start up completely! I was wondering do that necessary mean I have to replace my fuel pump??????
May 21, 2009 at 6:54 AM
Check what's missing fuel or spark? Do below
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
May 21, 2009 at 10:05 AM
