1995 Chrysler Cirrus charge a/c
90,000 MILES • 6 CYL • FWD • AUTOMATIC
R LANGSHAW
i want to charge the a/c but iam unable to find the
low pressure switch to jump across so the compressor
will run to accept freon or is there another way to get
the compressor to accept a charge
Jun 23, 2009 at 4:50 AM
BUDDYCRAIGG
  • 2,262 POSTS
I always start with my first can of freon in a big pan of hot water taken right off the stove.
The hot water helps get the whole can in to the car. By then there should be enough pressure in the system for the compressor to cycle.
Jun 23, 2009 at 5:47 AM
