1995 Chrysler Cirrus Changing Spark plugs
156,430 MILES • 6 CYL • 2WD • AUTOMATIC
LENAYEA
Hi I am a mother of five and been maintaing my own car for quite some time three months ago I bought a 1995 Chrysler Cirrus LX V6 2.5 and I am having trouble with finding the spark plugs if someone could help me I would greatly appreciate it.
Jun 3, 2009 at 6:43 AM
DOCFIXIT
  • 18,828 POSTS
O.K.
Locate distributor follow each wire to the spark plug
Jun 3, 2009 at 7:07 AM
ZACKMAN
  • 4,202 POSTS
The front three is quite self explanatory. But for the back three, you have to remove the upper intake manifold.
Remove the sensor connectors on the intake manifold. There are 7 bolts on the top and and two on the sides (one on each side) towards the firewall. Also remove the two bolts holding the EGR pipe. Remove accelerator and cruise control cables from the throttle body. Remove the vacuum hoses from the manifold, and the manifold is ready to come out.
Then you should see the other three spark plug wires.
Jun 3, 2009 at 7:10 PM
