1995 Chrysler Cirrus alarm
93,710 MILES • 6 CYL • FWD • AUTOMATIC
WILLIAM GREENE
i locked my car door and the next mourning i went to get in car and i unlocked the door ( with key ) . it set the alarm off and the fuel pump is in the alarm system . the car will start and then cut off . it will not cut of . i have unhooked the batary and them tried it . it did not help . i do not know anything else to do . i told the dealer and he does not know anything about it . plsease help .
Mar 27, 2008 at 12:34 PM
BMRFIXIT
  • 19,053 POSTS
use the key in the other door and or the trunk
and if all didn’t work you need to check the fuel pump if you think it fuel issue
Mar 27, 2008 at 1:30 PM
