2008 Chrysler Aspen oil pan
MINIMAHK
Engine Mechanical problem
2008 Chrysler Aspen V8 Four Wheel Drive Automatic
to remove the oil pan do i have to also remove the rack and pinion and the front diff or do u know a trick of some sort??
Apr 28, 2010 at 2:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the steering rack does have to be unbolted and lowered but the lines can remain connected. the front axle must also be lowered on the 4x4 model. also loosen engine mounts and raise engine to provided clearance of pan.
Apr 28, 2010 at 3:54 PM
