2007 Chrysler Aspen Check Engine Light
CGB
Engine Performance problem
2007 Chrysler Aspen 29700 miles
I was driving to work and check engine light came on. Vehicle runs fine and haven't had any problems. What could this be?
Nov 6, 2008 at 1:31 AM
DOCFIXIT
  • 18,828 POSTS
Go to an Auto Zone they will read code then post and will help.
Nov 6, 2008 at 3:52 AM
CGB
[quote:56709281a1="Docfixit"]Go to an Auto Zone they will read code then post and will help.[/quote:56709281a1]
Went to Auto Zone. Reading said is either (1) cam sensor; (2) wiring to cam sensor; or (3) jumped timing
Called service center before going to Auto Zone and he said he's commonly seen a loose gas cap cause this and sometimes it takes a few "computer cycles" before it will go off. I filled up this morning and after starting vehicle for 3rd time since, the light has gone off. Could this have been the problem?
Nov 6, 2008 at 5:15 AM
DOCFIXIT
  • 18,828 POSTS
Yes the cap off or loose will set light I think your good
Nov 6, 2008 at 5:34 AM
