POWER FEATURES NOT WORKING!
CHAMI
I have 1990 Chrysler 5th Avenue New Yorker 3.3L engine car. Recently my Air condition fan blower air is going to the floor even when I put to the pannel. So I tide the flipper near the fan blower so now air comes to through the panel!
I had my car switch turned on and at the same time I disconnect my battery before I was doing anything fixing this. While the car switch is on, I plug the battery back in!
I do not know why that now my driver side and passenger side power side mirrors not working, power seat does not move front and back in the driver side, also power door locks not working, However, from driver side I can open close all the windows!
I checked all the RELAY modules and all seems to be working fine! But I there is a Relay module called E F, it seems to me that I am not getting power on F module and E module working fine which is for passenger side and that only power door is not working.
I am pretty much sure that something must have happen because I plug the battery in while my car swtich is on and something could have happen that I do not understand
I am glad if anyone can tell me is there any computer that I should reset that controls all the things?
Again, these are the things that does not work!
Driver side power seat cannot move front and back.
Driver side power mirror and door locks are not working.
Driver side all Power windows working!
Passenger side power seats working
Passenger side power windows working
Passenger side door locks not working
Passenger side power side mirrors not working
I am glad if anyone can let me know how to reset if there is any computer thing to control all this along with Relay modules!
Jul 10, 2006 at 2:48 PM
RUNTICH
  • 27 POSTS
There is nothing that u can reset but check all ur fuses.
Jul 13, 2006 at 4:16 PM
CHAMI
Yes, fuses does not show anything to do with unlock buttons. However, I checked RELAY MODULES and I realize that E relay module or F relay module is not getting power. I am thinking what makes it not getting power to one relay module? Those modules working fine!
Thank you for reply and please let me know that what makes power not coming to relay modules? Are not power coming to relay modules straight from a battery or is there another path which it would take?
:roll: :roll: :roll: :roll:
Jul 13, 2006 at 4:21 PM
RUNTICH
  • 27 POSTS
the relays get power from a fuse, even though there is not a fuse just for the power windows it probably runs though another fuse. To find out which ones to check u will need a wiring diagram.
Jul 14, 2006 at 1:44 PM
CHAMI
Okay, I will try. So I hope you are sure about it. This car is Chrysler 1990 5th Avenue New Yorker.
I will post against if it does not work. I have no idea though what exact fuse to look for since it does not really say it is for power door locks. I know that power does not come to E or F Relay Modules. Thanks for the replies. I will check.
Jul 14, 2006 at 1:48 PM
