left blinker fails to blink
CHRYSLER FIFTH AVENUE
JWILL56
I have a 1992 New Yorker with 113k miles. v6 eng. The left blinker has failed and I replaced both bulbs but still same problem. Is there a relay involved? If so, where will I find it? Thanks.
Nov 21, 2007 at 11:54 PM
MERLIN2021
  • 17,250 POSTS
Yes there is a flasher but if the right side works that's doubtful...check the wires at that pigtail, and the amount of corrosion, and water in the socket...you can buy a new pigtail if needed!
Nov 22, 2007 at 12:32 AM
JWILL56
I gave a brief check of the pigtail but didn't put much into it since the brake and running lights still work. Thats why I thought a relay/flasher may be faulty. I'll do a more closer inspection and see what I find. Thanks for the prompt reply.
Nov 22, 2007 at 12:45 AM
