coolant leak dripping between engine and tranny
ERIK WATSON
  • 7 POSTS
i have a 1988 chrysler fifth avenue 5.2 liter i am leaking coolant and i cant figure out where it is coming from the coolant is dripping off the engine right where the engine meets the transmission directly above the starter is it possible that it is actually leaking from between the engine and transmission also there is a line that goes from the top of the water pump to the rear of the engine but i do not know where exactly it leads and it is hard to get to it behind the carb so i cant tell if that is leaking where i cant see can you tell me where this line leads to on the engine and if it is possible for it to leak from between the engine and transmission thank you very much for your time (p.s. i previously thought it was the freeze plug right above the starter but that was incorrect since i changed it and its still leaking and dripping of the edge of the crank case right at the corner)
Nov 21, 2007 at 8:28 AM
BMRFIXIT
  • 19,053 POSTS
[quote:91b85bc15d="erik watson"]i have a 1988 chrysler fifth avenue 5.2 liter i am leaking coolant and i cant figure out where it is coming from the coolant is dripping off the engine right where the engine meets the transmission directly above the starter is it possible that it is actually leaking from between the engine and transmission also there is a line that goes from the top of the water pump to the rear of the engine but i do not know where exactly it leads and it is hard to get to it behind the carb so i cant tell if that is leaking where i cant see can you tell me where this line leads to on the engine and if it is possible for it to leak from between the engine and transmission thank you very much for your time (p.s. i previously thought it was the freeze plug right above the starter but that was incorrect since i changed it and its still leaking and dripping of the edge of the crank case right at the corner)[/quote:91b85bc15d]
did u check if its dripping from the fire wall area
Heater core
Nov 21, 2007 at 9:58 AM
ERIK WATSON
  • 7 POSTS
[quote:6a315e5b80="BMRFIXIT"][quote:6a315e5b80="erik watson"]i have a 1988 chrysler fifth avenue 5.2 liter i am leaking coolant and i cant figure out where it is coming from the coolant is dripping off the engine right where the engine meets the transmission directly above the starter is it possible that it is actually leaking from between the engine and transmission also there is a line that goes from the top of the water pump to the rear of the engine but i do not know where exactly it leads and it is hard to get to it behind the carb so i cant tell if that is leaking where i cant see can you tell me where this line leads to on the engine and if it is possible for it to leak from between the engine and transmission thank you very much for your time (p.s. i previously thought it was the freeze plug right above the starter but that was incorrect since i changed it and its still leaking and dripping of the edge of the crank case right at the corner)[/quote:6a315e5b80]
Heater core[/quote:6a315e5b80]
it isnt leaking around firewall it is leaking in the rear driverside corner of the block litterally right off the crank case
Nov 21, 2007 at 10:00 AM
BMRFIXIT
  • 19,053 POSTS
[quote:d51bc73d7c="erik watson"][quote:d51bc73d7c="BMRFIXIT"][quote:d51bc73d7c="erik watson"]i have a 1988 chrysler fifth avenue 5.2 liter i am leaking coolant and i cant figure out where it is coming from the coolant is dripping off the engine right where the engine meets the transmission directly above the starter is it possible that it is actually leaking from between the engine and transmission also there is a line that goes from the top of the water pump to the rear of the engine but i do not know where exactly it leads and it is hard to get to it behind the carb so i cant tell if that is leaking where i cant see can you tell me where this line leads to on the engine and if it is possible for it to leak from between the engine and transmission thank you very much for your time (p.s. i previously thought it was the freeze plug right above the starter but that was incorrect since i changed it and its still leaking and dripping of the edge of the crank case right at the corner)[/quote:d51bc73d7c]
Heater core[/quote:d51bc73d7c]
it isnt leaking around firewall it is leaking in the rear driverside corner of the block litterally right off the crank case[/quote:d51bc73d7c]
That’s leave me with two suggestions head gasket
Intake manifold gasket
Nov 21, 2007 at 10:26 AM
ERIK WATSON
  • 7 POSTS
[quote:21c9378360="BMRFIXIT"][quote:21c9378360="erik watson"][quote:21c9378360="BMRFIXIT"][quote:21c9378360="erik watson"]i have a 1988 chrysler fifth avenue 5.2 liter i am leaking coolant and i cant figure out where it is coming from the coolant is dripping off the engine right where the engine meets the transmission directly above the starter is it possible that it is actually leaking from between the engine and transmission also there is a line that goes from the top of the water pump to the rear of the engine but i do not know where exactly it leads and it is hard to get to it behind the carb so i cant tell if that is leaking where i cant see can you tell me where this line leads to on the engine and if it is possible for it to leak from between the engine and transmission thank you very much for your time (p.s. i previously thought it was the freeze plug right above the starter but that was incorrect since i changed it and its still leaking and dripping of the edge of the crank case right at the corner)[/quote:21c9378360]
Heater core[/quote:21c9378360]
it isnt leaking around firewall it is leaking in the rear driverside corner of the block litterally right off the crank case[/quote:21c9378360]
Intake manifold gasket[/quote:21c9378360]
yeah thats what i was thinking i just have never heard of it leaking from between the engine and transmission i was just hoping that it might be the hose that i cant seem to get too to track down because it is right over the leak almost
Nov 21, 2007 at 10:35 AM
BMRFIXIT
  • 19,053 POSTS
[quote:c595d62ed0="erik watson"][quote:c595d62ed0="BMRFIXIT"][quote:c595d62ed0="erik watson"][quote:c595d62ed0="BMRFIXIT"][quote:c595d62ed0="erik watson"]i have a 1988 chrysler fifth avenue 5.2 liter i am leaking coolant and i cant figure out where it is coming from the coolant is dripping off the engine right where the engine meets the transmission directly above the starter is it possible that it is actually leaking from between the engine and transmission also there is a line that goes from the top of the water pump to the rear of the engine but i do not know where exactly it leads and it is hard to get to it behind the carb so i cant tell if that is leaking where i cant see can you tell me where this line leads to on the engine and if it is possible for it to leak from between the engine and transmission thank you very much for your time (p.s. i previously thought it was the freeze plug right above the starter but that was incorrect since i changed it and its still leaking and dripping of the edge of the crank case right at the corner)[/quote:c595d62ed0]
Heater core[/quote:c595d62ed0]
it isnt leaking around firewall it is leaking in the rear driverside corner of the block litterally right off the crank case[/quote:c595d62ed0]
Intake manifold gasket[/quote:c595d62ed0]
yeah thats what i was thinking i just have never heard of it leaking from between the engine and transmission i was just hoping that it might be the hose that i cant seem to get too to track down because it is right over the leak almost[/quote:c595d62ed0]
I would look 1st into the manifold gasket
But also the head gasket they break by the water jacket allowing the coolant to leak out
Nov 21, 2007 at 10:43 AM
ERIK WATSON
  • 7 POSTS
[quote:2ffc9c1ac5="BMRFIXIT"][quote:2ffc9c1ac5="erik watson"][quote:2ffc9c1ac5="BMRFIXIT"][quote:2ffc9c1ac5="erik watson"][quote:2ffc9c1ac5="BMRFIXIT"][quote:2ffc9c1ac5="erik watson"]i have a 1988 chrysler fifth avenue 5.2 liter i am leaking coolant and i cant figure out where it is coming from the coolant is dripping off the engine right where the engine meets the transmission directly above the starter is it possible that it is actually leaking from between the engine and transmission also there is a line that goes from the top of the water pump to the rear of the engine but i do not know where exactly it leads and it is hard to get to it behind the carb so i cant tell if that is leaking where i cant see can you tell me where this line leads to on the engine and if it is possible for it to leak from between the engine and transmission thank you very much for your time (p.s. i previously thought it was the freeze plug right above the starter but that was incorrect since i changed it and its still leaking and dripping of the edge of the crank case right at the corner)[/quote:2ffc9c1ac5]
Heater core[/quote:2ffc9c1ac5]
it isnt leaking around firewall it is leaking in the rear driverside corner of the block litterally right off the crank case[/quote:2ffc9c1ac5]
Intake manifold gasket[/quote:2ffc9c1ac5]
yeah thats what i was thinking i just have never heard of it leaking from between the engine and transmission i was just hoping that it might be the hose that i cant seem to get too to track down because it is right over the leak almost[/quote:2ffc9c1ac5]
But also the head gasket they break by the water jacket allowing the coolant to leak out[/quote:2ffc9c1ac5]
cool thanks again for the advice
Nov 21, 2007 at 12:25 PM
