1993 Chrysler 5th Avenue rear brake
148,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLUECOLLAR MAN
how to get rear drum off to get to shoes
Mar 15, 2008 at 5:47 AM
  • 110,244 POSTS
Hi:
First, make sure the e brake is off. Next, on the rear of the backing plate, you will find a rubber plug. Remove the plug with a screwdriver. Inside is the self adjuster that automaticly adjust the brakes as they wear. There is a star wheel you will see. It will need to be loostened so the shoes move away from the drum, thus allowing the drum to come off. Also, don't be afraid to tap on the sides of the drum with a hammar to loosten rust and dirt.
If you have any other questions, let me know.
Nov 1, 2008 at 1:58 PM
