1993 Chrysler 5th Avenue noise in rear of car
LINDAMCKEE
Brakes problem
1993 Chrysler 5th Avenue Automatic
We just replaced the brakes and drums and now when you put the car in drive and move forward or reverse it makes a loud whining sound. Could we have done something wrong when replacing the brakes? The noise was not there before doing the brakes. thank-you
Nov 15, 2009 at 3:12 AM
MERLIN2021
  • 17,250 POSTS
Wheel bearings may be damaged! Remove and check for flaking, if found install new bearings and races, then install like this:
Installation 1. To install, reverse removal procedure. Seat new races into drum or hub. Pack bearings using multi-purpose grease. Install inner bearing and new seal. 2. Clean and inspect spindle. Apply a thin coat of wheel bearing grease to polished surfaces. Install drum or hub on spindle. Install outer bearing, washer and adjusting nut. 3. Tighten adjusting nut to 20-25 ft. lbs. (27-34 N.m). Back off adjusting nut 1/4 turn. Finger tighten adjusting nut. Position nut lock with slots in line with cotter pin hole on spindle. Install cotter pin, grease cap and wheel. NOTE: DO NOT reuse old grease seals.
Nov 15, 2009 at 3:20 AM
