1993 Chrysler 5th Avenue Elect.fuel pump no power
1993 CHRYSLER FIFTH AVENUE
98,243 MILES • 6 CYL • FWD • AUTOMATIC
PAULDOG7074
What is killing the power to my fuel pump. There is 12v. at the shutoff relay. Also 12v. at the fuse. But not at the pump?? Please help!
Jul 10, 2009 at 3:39 AM
MERLIN2021
  • 17,250 POSTS
FUEL DELIVERY Automatic Shutdown (ASD) Relay ASD relay is energized when ignition is on. If PCM does not receive a distributor signal (camshaft or crankshaft sensor signal on DIS models), PCM will de-energize ASD relay. When ASD relay is de- energized, power to fuel pump, fuel injectors, ignition coil and O2 sensor heater element is interrupted.
https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
This relay is in the under hood fuse block(power distribution center).
Jul 11, 2009 at 2:09 AM
