1992 Chrysler 5th Avenue SHIFTING
JESSEMO
Transmission problem
1992 Chrysler 5th Avenue 6 cyl Front Wheel Drive Automatic
WENE I DRIVE DOWN THE ROAD MY CAR WONT SHIFT GEARS
Jul 1, 2009 at 9:26 AM
CH112063
  • 1,320 POSTS
Hello, Are you still in need of an answer to your transmission shifting problem, if you are, let me know. Your car has a type of transmission(overdrive) that when it fails either hydraulicaly or electricaly it goes into a 'limp-in mode". You will only have 2nd. gear. If you still need a question answered, I'll look out for you.
Good luck.
Aug 26, 2009 at 11:09 AM
THE_FIFTH
I too kinda have the same problem I cant go into reverse and wont shift through gears
Nov 25, 2009 at 5:51 AM
CH112063
  • 1,320 POSTS
Hello to you. A chrysler built overdrive 4 speed auto transaxle has a built in feature that helps a driver drive their car when an hydroelectric problem exists. This can be anything from a fluid pressure loss(leak) to a fuse, relay, or even a failed internal apply function that can only cause more damage. You can still try the other forward gear selections, but only a scanner(electronic tool) will point out the diagnostic starting point. Check for any fluid loss and the level of the transmission in Park. Hot. If you have any transmission codes or engine codes from a scan of their computers and are curious as to their vaslidity, just ask. Or see the 'site menu' it has many informative details on this problem. Sometimes it can mean buying a new car. Or just need a service, with a new filter and oil change. The higher the mileage, the more chance it may be more serious. ok
Nov 25, 2009 at 11:33 AM
