1992 Chrysler 5th Avenue help
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
STRYKER1432
HI I HAVE A 1992 5TH AVE. GREAT CAR BUT I HAVE A PROBLEM I NEED HELP ON. AFTER DRIVING FOR ABOUT 10 TO 12 MILES THE DIGITAL SPEEDOMETER WILL START WORKING AND THE THE DOORS FINALLY WILL LOCK AND THEN THE CRUISE CONTROLL WILL WORK.. AND ALSO THE STEREO AND POWER ANTENNA HAS SOMTHING WRONG THE ANTENNA WILL GO DOWN AFTER A WHILE AND IF I HIT THE DASH IT WILL GO BACK UP... CAN ANYONE HELP.. IT ASLO HAS ANTITHEFT SYSTEM FROM FACTORY...
Jan 6, 2008 at 4:08 AM
  • 110,244 POSTS
Hi:
It sounds like you have a ground problem, or a broken wire under the dash. To find it may take some time. Because of the involvement in the procedure, I recommend you take to an auto electric shop for repairs.
Nov 1, 2008 at 2:48 PM
