1992 Chrysler 5th Avenue digital fuel gauge alwayes reads f
69,000 MILES • 6 CYL • FWD • AUTOMATIC
RDUFFER
my digital fuel gauge is always pegged on full...all other gauges work fine. is there a way to fix this . ,,i was told it was a ground problem..where would the ground be located, if that is the problem. thank you very much.
Aug 7, 2008 at 10:25 AM
  • 110,244 POSTS
Hi:
Yes it could be a ground problem or a short. However, chrysler fuel pumps and float level are one unit which are known to go bad. I would start looking for shorts or ground problems near the fuel tank. If you have no luck, a new fuel pump / float may be your only answer.
Oct 15, 2008 at 3:52 PM
