1992 Chrysler 5th Avenue Car keeps dying
109,000 MILES • 6 CYL • FWD • AUTOMATIC
JEFFSTEPHMOORE
Sometimes when I apply the brakes, the car shudders. Also, it randomly will not start. The radio and clock reset so I had the battery checked. (It's only 18 mos old). Auto Zone said it was fine. Can you help me?
Thanks,
Stephanie
Oct 21, 2008 at 11:44 AM
  • 75,988 POSTS
Hi jeffstepmoore and welcome to 2carpros
If you refering this as cranking over and refusing to start-check the fuel pressure could be the fuel pump is failing
Oct 21, 2008 at 11:49 AM
JEFFSTEPHMOORE
When I say that it will not start, I mean that it will not even turn over and then after a few or 100 tries it will start right up.
Oct 21, 2008 at 11:56 AM
  • 75,988 POSTS
Double check battery connection -also the ground at engine and hot at starter side
Start by checking the starter, starter relay, park and neutral switch and ignition switch
Oct 22, 2008 at 7:28 AM
