1991 Chrysler 5th Avenue my radio is on and wont play becau
1991 CHRYSLER FIFTH AVENUE
126,000 MILES • 6 CYL • FWD • AUTOMATIC
AENIMA95
i got this car a couple of days ago and it works fine until something happened with the radio its on but the antenna doesent come up, and on the radio there a two letter NR which i dont know what that means
Jul 17, 2008 at 2:48 AM
  • 110,240 POSTS
Hi:
NR is feature the raido has, Noise Reduction. If the antenna is electric and doesn't go up, chances are the motor is bad on it. However, it could be a short. If you would like to check it, find the motor (under the antenna) and check if there is power coming to it. let me know what you find.
Oct 16, 2008 at 12:33 AM
