1991 Chrysler 5th Avenue Horn relay
1991 CHRYSLER FIFTH AVENUE
65,200 MILES • 6 CYL • 2WD • AUTOMATIC
DESERET RIDER
I can't find the horn relay---the book says these relays are at the lower right of the instrument panel near the fuses------but I can't see any relay panel there?-------my horn desn't work---the fuse is good---and I read no voltage at the dual horn connectors when the horn buttons are pushed. I expect the horn relay may be bad----but I an't find it Do I have to remove dash panels to find it or what?
Jul 5, 2008 at 8:13 AM
  • 110,244 POSTS
Hi:
The horn relay is on the relay block. If you can't find it under the dash, check under the hood.
Oct 16, 2008 at 12:59 AM
