1991 Chrysler 5th Avenue Fault Code 62
180,000 MILES • 6 CYL • FWD • AUTOMATIC
CJAVENI
  • 11 POSTS
Hello, and thanks for your assistance in advace. The above vehicle with a 3.3L engine is setting a fault code 62. The OEM service manual does not reference this code. From google searches, I found that this fault(although not sure if it pertains to this vehicle) indicates - 62 PCM failure SRI mile not stored. So I replaced the SBEC. Still have the same error. Most of the emission sensors have been replaced on this vehicle expcept for the TPS and Vaccum sensor. I do notice on occasion that car will stall, although, since I have replaced the SBEC, the problem hasnt reoccured(only two days though). The Check Engine light never comes on, but if you check the codes you have 12 - 62 -55. Please also not that I am sure that I am reading the codes correctly. Any suggestions are greatly appreciated.
Chris
Jun 10, 2009 at 5:14 AM
JDL
  • 16,098 POSTS
Hello, my info says that code is EMR, emissions maintenance reminder, you may need a chrysler scan tool to reset.
Jun 10, 2009 at 6:07 AM
CJAVENI
  • 11 POSTS
Does this cause drivability issues, and wouldnt replacing the SBEC take care of this? What sets this off? Also note that there is no EMR light in the dash.
Jun 10, 2009 at 6:10 AM
CARADIODOC
  • 34,410 POSTS
The emissions maintenance reminder system is only used on vehicles with the truck exhaust systems which includes minivans.
The codes are displayed in numerical order. 12 just means the ignition switch was turned off. 55 is end of the message and is the highest number there is for this car. Not sure how a "62" popped up in between the two.
caradiodoc
Jun 19, 2009 at 4:22 PM
