1988 Chrysler 5th Avenue Wont start
55,315 MILES • V8 • 2WD • AUTOMATIC
DEAUNTRA68
When I put my key in the ignition, it makes one click sound and it wont start, what do you believe the problem is
Feb 18, 2009 at 2:45 AM
CARADIODOC
  • 34,391 POSTS
Very common problem. Worn contacts in the starter solenoid. Keep trying it; it will crank eventually. The contacts can be replaced by a competent do-it-yourselfer. Cost is about $15.00.
You can also replace the entire starter but cost is a lot more.
caradiodoc
Mar 28, 2009 at 9:31 PM
