1987 Chrysler 5th Avenue rough running/stalling at evry sto
WOCHUCK_44
Engine Performance problem
1987 Chrysler 5th Avenue V8 Two Wheel Drive Automatic
What would cause my engine to run rough and stal t every stopp
Jul 9, 2010 at 11:12 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Jul 10, 2010 at 8:48 PM
