1987 Chrysler 5th Avenue Air Conditioning Problems
1987 CHRYSLER FIFTH AVENUE
97,000 MILES • V8 • 4WD • AUTOMATIC
DUB31
Hi, I own an 87' Chrysler Fifth Ave and when i turn on the Air conditioning System the air only comes out from the top air vents and nothing from the front. Only the top and bottom. The air does come out cold.
Feb 9, 2009 at 2:22 PM
DOCFIXIT
  • 18,828 POSTS
Problem in controler or blend door actuator not functioning
Feb 10, 2009 at 3:00 AM
DUB31
Where would the controler or blend door actuator be in my 87 Chrysler Fifth Ave?
Feb 10, 2009 at 12:52 PM
DOCFIXIT
  • 18,828 POSTS
Controler is the thing where all the switches for AC/heat
The blend door actuators are up under dash. On you model should be vacuum controled.
Feb 11, 2009 at 2:21 AM
