1986 Chrysler 5th Avenue
YOLANDASMITH
What is the black bar/rod that supports the alternator, a long bolt runs through it. Someone said it's an alternator and compressor bracket, I looked at a picture but it doesn't look like it. Presently the alternator is hanging and my belts squeal. The bar is attached at possibly the top of the motor and it attaches the alternator, it's not on the bottom where you can tightened the belts.
Jul 26, 2008 at 6:35 AM
  • 110,248 POSTS
Hi:
That is a support for the alt. To tighten the belt, you will need to loosten all of the mounting bolts, tighten the alt, and retighten the mounting bolts.
Nov 1, 2008 at 1:26 PM
