1985 Chrysler 5th Avenue Turn signals
1985 CHRYSLER FIFTH AVENUE
DNVRLUV
Electrical problem
1985 Chrysler 5th Avenue V8 Two Wheel Drive Automatic
My left turn signal works great but the right signal used to flash slowly but now it dont at all I already replaced the flasher but I still get the same results does anyone know how i can fix this problem or suggestions on what I do?
Aug 4, 2008 at 12:08 PM
  • 110,244 POSTS
Hi:
If it doesn't flash and you replaced the flasher, it sounds like you may have a bad bulb or socket. Turn the right signal on and see if any of the lights are working. If you find one is not, replace it.
Let me know if you have any other questions.
Oct 15, 2008 at 3:55 PM
