1985 Chrysler 5th Avenue headlights
11,000 MILES • V8 • 2WD • AUTOMATIC
SCOTTNOBODY
pretty simple question... my low beam lights dont work but when i put my high beams on the low beam lighs still come on... i just need a wiring diagram so i can find were my problam might be
Nov 9, 2009 at 10:14 AM
CARADIODOC
  • 34,407 POSTS
Sorry for the delay in replying.
Do you mean the low beams only come on when selecting high beams or low and high beams come on at the same time? If both at the same time, how can you tell?
The wiring to the lights didn't up and change itself on its own, so I would suspect a defective dimmer switch or overheated / burned terminals. The switch is bolted to the left side of the steering column. The two mounting holes are slotted to allow for proper adjustment.
caradiodoc
Nov 26, 2009 at 3:43 PM
