1985 Chrysler 5th Avenue brake problem
KEENTEEN2U
Brakes problem
1985 Chrysler 5th Avenue V8 Four Wheel Drive Automatic 154k miles
Brakes continue to get more soft & spongy when being pumped. I put in nearly a whole can of Brake fluid in the master cylinder resevoir. Whats wrong?
Dec 7, 2007 at 11:45 AM
  • 110,244 POSTS
Hi:
Is the master cylender going low? If so, you will need to look for a leak. If there isn't a leak, check front brake rubber hoses to make sure they are not buldging when the brakes are applied and have the master cylender checked.
Nov 1, 2008 at 3:02 PM
