1985 Chrysler 5th Avenue
144,000 MILES • V8 • 2WD • AUTOMATIC
WALTER BEATTIE
I have no spark. the ignition system is the lean burn system that has a control module mounted on the air cleaner. I cannot find any good info on diagnosing this system. can you steer me in the right direction thanks
Water Beattie
Sep 5, 2008 at 5:04 AM
  • 110,248 POSTS
Is there power to the coil? Have you checked the cap and rotor?
As far as good information on the lean burn system, it will be hard to find because there arn't too many of them around any more. Regardless, lets see if we can figure it out.
PS: Have you checked out any of the manuals for the vehicle?
Oct 15, 2008 at 3:19 PM
