1985 Chrysler Fifth Avenue Hot Stall
POUTOUS
hi. I have an 1985 Chrysler 5th ave with 66000 miles (but may not be acurate). I can get it to start most times. But when the temperature reaches normal, the whole cars loses power and the engine shuts down completely and I cannot get it to restart untill it has cooled down (somtimes hours) I am buying a repair book but I dont know where to begin. Where should I look? What could cause the car to lose power / engine shut off when the temperature reaches normal or anything above cold actually.
Please Help ASAP
Thank You for the help- enjoy the donation :D
Dec 22, 2006 at 4:26 PM
2CARPRO JACK
  • 11,533 POSTS
85? is it fuel injected?. Could be the crank position sensor, sometimes when electronics get hot they fail. Next time the car wont start check for spark and fuel.That will help us help you
Dec 23, 2006 at 12:43 AM
Suggested Repair
When the engine will not restart, check for spark and fuel. A crank position sensor or other electronics that fail when hot is a possible cause.
Conversation Summary
A 1985 Chrysler Fifth Avenue starts when cold but loses power and shuts off once it reaches normal temperature, then will not restart until it cools. The expert asked whether it is fuel injected and suggested checking for spark and fuel during a no-start, noting that a crank position sensor or other electronics can fail when hot.
