Chrysler 300 Short
ICY360
  • 25 POSTS
I have a short in the electrical system, what should I look for?
Sep 3, 2009 at 10:55 AM
  • 75,988 POSTS
Make sure the ASD relay is in good shape if okay could be the computer controlled of the field generation circuit-see below charging circuit EWD unable to read give me your email addy
https://images.2carpros.com/forum/automotive_pictures/12900_charge_circuit_1.jpg
Sep 4, 2009 at 11:47 AM
ICY360
  • 25 POSTS
Sep 6, 2009 at 1:39 PM
MIKE H R
  • 3,094 POSTS
I agree with Raz, there is something else you can try. Disconnect the battery for a minute or two. This will clear the computer { on most car} It is not recommended by most dealers, but I have found it helpful. While the battery sis disconnected check for a bad ground, could be in a wire that looks perfectly normal but sometimes under it it is not making a good contact. With most any starting problems I recommend checking the wiring. After checking all the connections hook the battery back up. I recommend to charge a battery correctly is disconnet it from the car and charge it at a slow rate. If the car still does not turn over then try what Raz mentioned
Sep 23, 2009 at 3:17 AM
ICY360
  • 25 POSTS
Oh That is something I have tried.
Sep 27, 2009 at 4:53 PM
  • 75,988 POSTS
Ref. electrical short just sent the diagram a few minutes ago -good luck
Oct 4, 2009 at 1:08 PM
ICY360
  • 25 POSTS
This battery I purchased really must be a good battery brand.
Feb 14, 2010 at 10:07 AM
