Chrysler 300 Overheating
ICY360
  • 25 POSTS
overheating while driving, I have replaced the radiator and all the coolant hoses, but it still is getting too hot?
Jun 13, 2010 at 9:47 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
AS you have replaced with new just about the entire cooling system, i would be testing the thermostat for a fault just to be sure, and i would now be getting a head check done, this is a quick and simple chemical test to check for any traces of Co in the cooling system, if so this is a positive sine of a head or gasket problem, try this next.
mark (mhpautos)
Jun 13, 2010 at 6:22 PM
ICY360
  • 25 POSTS
Does a 210 degree thermostat sound right?
Jun 14, 2010 at 4:27 AM
  • 31,937 POSTS
The thermostat sounds a bit hot to me, is is a genuine one?
mark
Jun 14, 2010 at 11:36 AM
ICY360
  • 25 POSTS
I don't think it was an original one
Jun 15, 2010 at 7:51 AM
ICY360
  • 25 POSTS
Works like a new cooling system should now, I think it's a good idea to use a strainer cloth and a good funnell when changing this thermostat and the bleeding the system helps a lot too.
Jun 15, 2010 at 11:38 AM
BLUELIGHTNIN6
  • 16,542 POSTS
thanks for that info. it will help us better assist others in the future..thanks again for using 2CarPros.com!
Jun 25, 2010 at 7:01 PM
