overheating while driving, I have replaced the radiator and all the coolant hoses, but it still is getting too hot?
Jun 13, 2010 at 4:47 PM
Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
CAR REPAIR CONTRIBUTOR
Hi there,
Thank you for the donation,
AS you have replaced with new just about the entire cooling system, i would be testing the thermostat for a fault just to be sure, and i would now be getting a head check done, this is a quick and simple chemical test to check for any traces of Co in the cooling system, if so this is a positive sine of a head or gasket problem, try this next.
mark (mhpautos)
Jun 14, 2010 at 1:22 AM
ICY360
MEMBER
Does a 210 degree thermostat sound right?
Jun 14, 2010 at 11:27 AM
The thermostat sounds a bit hot to me, is is a genuine one?
mark
Jun 14, 2010 at 6:36 PM
ICY360
MEMBER
I don't think it was an original one
Jun 15, 2010 at 2:51 PM
ICY360
MEMBER
Works like a new cooling system should now, I think it's a good idea to use a strainer cloth and a good funnell when changing this thermostat and the bleeding the system helps a lot too.
Jun 15, 2010 at 6:38 PM
BLUELIGHTNIN6
thanks for that info. it will help us better assist others in the future..thanks again for using 2CarPros.com!
