2000 Chrysler 300M P0134 Code
SDK_RACER
  • 9 POSTS
2000 Chrysler 300m with 80,000kms. Ok I resently bought this car and when I was driving it home after buying it the check engine light came on. So I looked and it was giving me the code P0134 which is a Right upstream O2 Sensor error. So I took it to a mechanic and he recomended changing out the old O2 sensor. So I got him to do it, and clear the code. Not an hour after it came back on with the same P0134 code. Is there a fix to this because I have heard of a few 300m's to do this. It runs fine, no rough idle or anything. Just can't stand to see that engine light and code on.
Aug 17, 2007 at 2:49 PM
SERVICE WRITER
  • 9,123 POSTS
Yeah, you want to get that fixed regardless of the annoyance. It may be a defective sensor that was put in, have the mechanic double check his diagnosis and the sensor. It may also be a problem with the harness going to the sensor. If the problem is on his end, I would expect that to be a no charge. This is when having a trusted and ethical mechanic that you are loyal to really pays off.
Aug 17, 2007 at 10:54 PM
SDK_RACER
  • 9 POSTS
Well I trust the mecanic as he is a friend of ours. He hooked up his OBD reader, and said that both sensors (new and old one) seamed to be running the way they should. He just fiqured the old one could have been a worn out so it could be the cause. I don't think it's the senor in itself but the wireing harness going to the sensor might be the cause.
I ran across this on a different site.
"Oxygen Sensor Problem
On some 1995-1996 LH cars, the Malfunction Indicator Lamp may come on, and be accompanied by a possible sag or hesitation or rough idle problem. When you hook up a scan tool, you may find codes that indicate the right or left upstream O2 sensor is shorted to voltage. The cure here is not to replace the sensors, says Chrysler technical service bulletin 08-13-99, but to install a special jumper wire harness to correct the broken splice in the wiring harness. Ignition"
I know mine is not a 95 or 96 LH, but does this seam relevent to what my car is doing. Minus the rough idle that my car does not seam to have.
It is a Chrysler 3.5L OHC V6 Engine Service Bulletin
Aug 18, 2007 at 12:21 PM
SERVICE WRITER
  • 9,123 POSTS
What kind of wave pattern are the sensors producing? The front ones should have SIN curve and the rear ones should be flat lined.
Aug 19, 2007 at 12:11 AM
SDK_RACER
  • 9 POSTS
[quote:2344ba27ef="Service Writer"]What kind of wave pattern are the sensors producing? The front ones should have SIN curve and the rear ones should be flat lined.[/quote:2344ba27ef]
I'm sorry I don't really know.
Aug 19, 2007 at 4:17 AM
SERVICE WRITER
  • 9,123 POSTS
Well, you can certainly guess at it and hope it works....and it may. The TSBs are pretty much unique to the vehicle sometimes due to a glitch in the manufacturing process or part problem during a run in the assy. process in the bullitin you refer to, or so I believe.
While the symptoms match the cure may not. HAve your mechanic look at the wave patterns.
Aug 19, 2007 at 5:33 AM
SDK_RACER
  • 9 POSTS
Ok, I'll talk to him about it in the next day or two. How exactly do you look at the wave patterns? Can you do that with the OBD reader or is there some other instrument to do this.
Aug 19, 2007 at 9:09 AM
SERVICE WRITER
  • 9,123 POSTS
I would think your mechanic has a scanner that is capable of monitoring the wave patern. I'll try to post what they should look like tommorrow.
Aug 19, 2007 at 11:36 AM
SDK_RACER
  • 9 POSTS
Well he has done some testing, but he is not 100% sure. But he thinks that the Powertrain Control Module is the cause. He said that it works fine for 10 or so minutes, then the O2 senser frezes up for a while and does not change readings.
Aug 31, 2007 at 4:36 AM
SERVICE WRITER
  • 9,123 POSTS
https://images.2carpros.com/forum/automotive_pictures/30961_o2_waves_4.jpg
The bottom pic is how the waves should look. I think I would stay on the path of the O2 circuit before getting into a computer. Maybe run the car up in the air and monitor the wave pattern, while someone wiggles the harness to see if you can make the pattern change. Maybe tap on the sensor and look for a response. Maybe a defective sensor.
Aug 31, 2007 at 10:05 PM
SDK_RACER
  • 9 POSTS
Ok well he did more testing and we decided to go for the PCM. It's been installed for a week and 450kms and no problems at all. I'm hopeing that was the cure. Thanks for your help.
Sep 9, 2007 at 12:54 PM
SERVICE WRITER
  • 9,123 POSTS
A little more testing was smart, glad to hear the sound of success!
Sep 9, 2007 at 1:38 PM
Suggested Repair
After replacing the right upstream O2 sensor did not clear P0134, check sensor waveforms and the wiring harness, including a wiggle test, before condemning the computer. Further testing here pointed to the PCM, and replacing it cleared the code.
Conversation Summary
A 2000 Chrysler 300M set code P0134 for the right upstream O2 sensor. Replacing the sensor and clearing the code did not help, and the mechanic said both sensors appeared to respond normally. The owner asked whether an older Chrysler wiring-splice bulletin applied. The expert said that bulletin may not match this car and recommended checking O2 waveforms, wiggling the harness, and tapping the sensor before replacing the PCM. Further testing led the owner and mechanic to replace the PCM, after which the code stayed off for a week and about 450 km.
