2007 Chrysler 300 Tail lights
89,052 MILES • 6 CYL • 2WD • AUTOMATIC
MAXVALDIVIEZ
My tail light will not come on but my turn light n brake lights work just fine. I was wounding if one light bulb goes out will it stop the other side stop working. Thank if you help me
Oct 4, 2010 at 4:37 AM
JDL
  • 16,098 POSTS
I wouldn't think it would effect all your tail lamps for safety reasons. I would check the fuse in the diagram, first. When the park lamp relay is energized, it supplies voltage for the tail lamps. There could be other issues? Hopefully this is the correct diagram. It says fuse 8--15 amp, in the integrated power module.
https://images.2carpros.com/forum/automotive_pictures/170934_chrysler_300_tail_lamps_1.jpg
Oct 4, 2010 at 4:59 AM
