2007 Chrysler 300 fuses
45,000 MILES • 6 CYL • 2WD • AUTOMATIC
FELECIAPRATT
my windshield wipers continued to run after the car was cut off how is that possible when there is no power and could it be my fuse and where is the fuse box located
Feb 11, 2009 at 12:47 PM
  • 110,248 POSTS
Hi:
It the wipers work with the key off, then there may be a problem with the ignition switch itself. The switch determines when the power is off and on. I would start with that.
Mar 16, 2009 at 3:13 AM
