2007 Chrysler 300 Engine shuts off when second key is used
2007 CHRYSLER 300
17,500 MILES • 6 CYL • 2WD • AUTOMATIC
KAR3762
Recently purchased auto and when we use the second key (actually wifes key) to start car, car shuts off before you can even take it out of park. After a few trys it doesn't spark at all. We are assuming anti-theft device is shutting car down, but doesn't make sense as this was the key issued with the car. The key seems to be the issue but no one seems to have heard of such a thing before and am wondering if others have had problems.
May 17, 2008 at 2:11 PM
PAMPATX
The second key isn't programmed. I have a second key that is just for opening the door. if I try to start the car the car will start, but it will shut off in a matter of seconds. you need to take the key back and get it programmed.
Dec 11, 2008 at 9:41 AM
