2006 Chrysler 300 Will not shift out of park.
67,000 MILES • V12 • 2WD • AUTOMATIC
BGMRK17
My car will not shift out of park, engine starts what can be the cause?
Apr 16, 2009 at 1:17 PM
  • 110,248 POSTS
This may sound like a stupid question, but are the brake lights working? The switch actuates the plark lock solenoid.
May 3, 2009 at 12:16 PM
PAT GILKEY
Just to be sure after you asked; I checked. Yes the brake lights do come on when the brake pedal is depressed
May 14, 2009 at 10:43 AM
  • 110,248 POSTS
The the park lock solenoid is bad. It was hoping it was the brake light switch.
May 15, 2009 at 2:58 AM
FLEETMANAGER
There is second lock in the shifter that brakes and won't allow the cable to move. It can be repaired by raping a piece of wire around the plastic or you can replace the shifter. I do not recomend that you let the dealer doit. I had to because of a shortage of time and they stuck me for $500 by the time I got the tow, rental car for a day and the diagnostic fee and labor and part. You can get the part from moparpartsamerica.com for$120 or less.
Jun 4, 2009 at 7:37 AM
