2006 Chrysler 300 oil pressure
64,000 MILES • 6 CYL • 2WD • AUTOMATIC
EHIBBLER
my cars oil pressure indicator comes on when not accelerating, is this the pump going bad or the indicator itself? i have checked the oil level, made sure the filter and plug were tight
Mar 23, 2010 at 5:55 AM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge,if normal replace the oil pressure switch.If abnormal could mean oil pump and engine bearing.
Mar 23, 2010 at 10:27 AM
